tony-martin avatar image
tony-martin asked
0.8V at PV Controller terminal
Hi All
I have a MPPT 75/15 SmartSolar Charge Controller. I have a 200W Solar Panel. When I check the voltage in good sunlight the panel is putting out 20.9V. When I hook it up to the comtroller I only read 0.8V at the PV terminals of the controller.
Is this normal?
Cheers and thanks from any advice in advance.
Tony M
MPPT Controllers
klim8skeptic avatar image
klim8skeptic answered ·
Normally a such a low PV voltage reading will indicate reverse polarity connection of the PV panels.
Please check the PV polarity.
tony-martin avatar image tony-martin commented ·
Thank you and will do
tony-martin avatar image tony-martin tony-martin commented ·
100% spot on I messed up polarity when I made an Anderson plug harness.
