My Multiplus 24/1200/25-16 does not have the correct grid code for my country, how can I add it to the Multiplus?
Use ve configure and go to the grid tab in software. Be aware it is a set once. You can't change it.
I don't have the required grid code in the grid code selection tab
If you dont have your country specifically then other is the one to choose... And welcome to the club.
But you only need to change it if you are using ESS assistant.
Is VE.config and the firmware of the MultiPlus up-to-date?
I want to use the assistant's ECC. VE.Config current version- 9003242. Multiplus firmware -2617430.
Use victron connect and the mk3 adaptor and update the firmware of the inverter, and OTA update for the GX device you are using. As Matthias Lange - DE mentioned before proceeding.
Read here for instructions.
60 People are following this question.
