My PV state of charge is stuck at 0% while at float state. do i need a BMS?
More info please. What components does the installation consist of, photos, screenshots, system diagram?
So sorry for the late response, System is made up of MultiPlus 24/5000/120-100, BlueSolar Charger MPPT 150/70 (VE.Direct) and a CCGX
You also asked if you need a BMS, what battery do you have?
Is there a battery monitor/shunt in the system or does the 0% come from the battery monitor in the MultiPlus?
33 People are following this question.
