I already have a spare Multiplus II 48/3000.
Apart from the obvious reasons is there any reason to favour 1 Multiplus II 48/5000 over 2 x Multiplus II 48/3000 in parallel? This is for a single phase application as a UPS backup function for whole house, with charging battery bank from grid when power resumes, also have MPPT DC PVs off grid to charge bank during day.
This will be for a small house with 800W continuous load, peaking at 4000W for 15 minutes and occasionally 8000W for 30 seconds? the property has Gas mains and LED lighting, LED TV etc, , so the electrical loads on average are not huge.
1. I either buy another Multiplus II 48/3000 and put into parallel with existing unit I already have.
2. Buy Multiplus II 48/5000 and use stand alone with possibility of buying another Multiplus II 48/5000 in the future for parallel operation. Using the Existing Multiplus II 48/3000 to charge the battery bank independently off grid with with generator, also giving me independent single phase for any other dedicated circuits.
3. Continue with adding up to 3 Multiplus II 48/3000 in parallel if needed.
I like the idea of redundancy as I know Victron equipment will be getting harder to find next year when load shedding starts and would not like to be down if a dedicated unit fails and leaves me with no power until the unit is repaired or I can buy another (if available).
My experience in life always tells me that multiple smaller ones are always better that 1 big one!
I would prefer opinions from people who have had actually done the install and have it running and have experience of the real life pros and cons.
cheers
