Is it possible to temporarily disable grid code LOM detection on Multis any way other than using VEConfigure 3? Ideally using an auxiliary input?
I have a grid connected ESS system using Multis, I've installed a changeover switch on the input line to allow me to connect a generator in the case of a prolonged grid cut, but it won't sync with LOM active.
Yes I know it would have been better to buy Quattros, but its too late!
The current arrangement works, but it's a PITA having to get the laptop out if I want to put the generator on, then do it again to go back to grid.
Thanks, Guy
