Fra avatar image
Fra asked
Detailed info of Smartsolar Mppt routine and DC conversion efficiency
Good morning,
I would like to know if it is possible to get some information about the technical specifications of the victron smartsolar, from the victron staff.
In particular:
- the efficiency curves at various powers and mpp voltages.
- the working frequency of the processor
-adjustments per second of the MPPT routine.
I am evaluating a controller with an almost flat efficiency curve at any power at 99%.
And a double mppt routine with 6,000 changes per second.
And a 30mhz processor.
I noticed that the victron smartsolar in boost-mppt seems to vary the voltage up and down a little faster than once per second.
I also noticed that in case of partial shading of 33% of the panel longitudinally on purpose, the controller stays for 3 minutes on a false MPP losing 2/3 of power. (Negative fact).
Only after 3 minutes does it find the true mpp at about half voltage and recover all the power possible.
I also noticed a full swap of the voltage curve every 10 minutes lasting 10 seconds.
And I noticed that in case of sudden load increase from no-mppt phase to mppt phase the controller performs 4 complete swaps of the voltage curve (positive fact).
Thank you
MPPT Controllers
