I recently upgraded from AGM to LifePo4 batteries and need to upgrade my chargers.
you can use a Skylla charger for lithium batteries, provided it is controlled by the BMS. As the Skylla is a relatively dumb charger, it can be controlled with the remote on/off, and also, if you have a 2nd charge control relay, you can use the external current control to reduce the output to that required for balancing (0.5 - 1 A).
Skylla-IP65 product page (12v, 24v)
Skylla-i product page (24v)
Skylla-TG Charger product page (24v, 48v)
Skylla-TG GMDSS product page (24v)
29 People are following this question.
