ettienne avatar image
ettienne asked
MultiPlus II fuse size
The recommended fuse size for the MultiPlus II 48/3000 is 125A. The dealer recommended only 80A fuse. I do understand that Victron is taking the 6000w / 48v to get to 125A. Does this mean that the 80A fuse will blow when the inverter caters for appliances startup demand?
Multiplus-II
boekel avatar image
boekel answered ·
A 'slow' 80A fuse will be sufficient in most cases, 80A * 48V = 3.8kW and will not blow except if you manage to overload the inverter for long times somehow.
A 125A fuse can be used also, if the cabling is up to this.
5 comments
ettienne avatar image ettienne commented ·
Thank you for the advice Boekel. I will be using 35mm wire so I am not sure if this will handle the 125A
boekel avatar image boekel ♦ ettienne commented ·
80A is plenty for a 3k 48V system
35mm2 and 80A also perfect, I'd go 50mm2 for 125A.
Jay avatar image Jay boekel ♦ commented ·
What about on the AC side? The Multiplus II 48v 5000 has a max AC input of 50A according to datasheet. So in ESS mode, the AC fuse should be 55A/63A? Would this suffice for peak power etc? I assume daisy chained units each would have this AC fuse then a rotary isolator accordingly of the same AC amperage?
sharpener avatar image sharpener Jay commented ·
I have mine on a 50A Type C circuit breaker and it has not tripped in 6 months of use as a whole-house ESS. And a rotary isolator to meet the UK requirement for a two-pole switch that is lockable. For compactness this is actually a 4-pole 25A isolator with the contacts paralleled, which is OK as it is not intended to be routinely disconnected under load.
Jay avatar image Jay sharpener commented ·
Very helpful thank you. Under what condition had the 50A Type C breaker previously tripped?
