markus32 avatar image
markus32 asked
Multiplus II and Hoymiles Microinverters
The Multiplus II can control the output power of an inverter using the frequency: the higher the frequency the MP2 creates, the lower the output of the inverter. This works well with Fronius inverters.
Question: Does this also work with Hoymiles inverters? HM-1500 for example.
Multiplus-II
ojack avatar image ojack commented ·
This would be interesting for me to.
I would like to install the single phase HM-1500 and the three phase HMT-1800-6t at ACout1 on a three Phase System of 3 MP2 3000.
kai-fuchs avatar image
kai-fuchs answered ·
Are there any updates on this topic?
jetlag avatar image
jetlag answered ·
I would say, yes, this should work. This is, as far as I remember, a request of the VDE AR-N-4105 (at least for Germany).
I don't have access to the docuement, but once had the chance to have an insight. It should be this chapter: 5.7.4.3 Verhalten der Erzeugungsanlage am Netz - Wirkleistungsanpassung bei Über- und Unterfrequenz
And additionally, Andy from the Offgrid Garage, has such a combo running with the MP2 and some other "Micro-Inverter" and this works fust fine. Please check his youtube channel.
As the Hoymiles Inverters are all qualified against the german standard, I would say this should work.
ojack avatar image
ojack answered ·
Yes it works with my Hoymiles HM-1500 and HMT-2250-6T.
And it should work with every inverter which fulfills the regulations of grid coupled operation.
alexander-uhde avatar image
alexander-uhde answered ·
This does also work well with APSystems microinverters on my site.
But you should be aware that frequency shifting will only Work off-grid.
If the MP2 ist connected to the grid via Ac-in IT cannot shift the frequency on Ac-out.
Regards
Alex
jetlag avatar image
jetlag answered ·
And the corresponding assistant in the MP2 must bei implemented.
