jakudo avatar image
jakudo asked
Connecting multiple mppt - advice needed
I’m going to have a Victron instalation from local company. It contains:
- 3x Multiplus II 48/3000
- MPPT SmartSolar 150/100-Tr
- 12x 450Wp panels
- 3x Pylontech US3000C
- GX monitoring
I have bought additional 8x 260Wp panels from a friend for a very good price and want to add them to the system. The company doesn’t want to do that by themselves, so I have to do it by myself. I’ve calculated MPPT from the Victron calculator and here are some questions:
- is it a problem that the two mppts are not the same size?
- will I see both in the VRM portal? I read that if I connect them via VE.Direct, it would be possible. Is that correct?
- just to be sure, with multiple mppts, I also need the SmartShunt
- anything else I need to be aware?
Thanks a lot
MPPT Controllers
4 comments
- 12x 450Wp panels
I would be asking for details about the suitability of a 150-100 being connected to 12 x 450w panels.
Victron online MPPT calculator.
jakudo avatar image jakudo klim8skeptic ♦ commented ·
Well, that's the company responsibility. I have 5 years warranty, so it should work well :D
The panels are Sunpro 450 Wp https://ecoprodukt.cz/product/31316/download/M6-mono-440-450W.pdf
I've checked the MPPT calculator,
https://mppt.victronenergy.com#djE7Y3VzdG9tLDIsNiw1NCwtMTAsNzAsNDgsMTAuOTgsMC4wNDksMTEuNTYsNDUwLDQxLC0wLjI2LDQ5LjgsMTAsNg==
So I guess, it should be ok, shouldn't it?
klim8skeptic avatar image klim8skeptic ♦ jakudo commented ·
The figures add up.
Keep an eye on the mppt output though. You could easily loose a couple of strings, and take a while to notice...
ok, thanks for advice
klim8skeptic answered ·
No. Just make sure you have pv strings that voltages/currents that are within the mppt's pv input specs.
Yes
NO, the BMS will pass voltage/current/SOC onto the GX.
Read the .Pylontech Product & system compatibility page.
Esp the "2. Minimum Battery Sizing Recommendations".
jakudo avatar image jakudo commented ·
thanks a lot for the answers. Ok, I will check the battery sizing.
Jakub
sharpener avatar image sharpener jakudo commented ·
With 6 parallel strings you have potentially got >60A in 6mm^2 cable and a voltage drop of 4V which is double the 3% allowed. Get them to increase the cable to 10mm^2.
