I have two Multiplus inverters installed in my motorhome. EMF readings at the inverters while these inverters are operatin are very high. The readings are reduced but still very high on the inside of the coach. I have tried to put EMF reducing cloth (purchased on Amazon) around the inverters and it doesn't make a difference. I wonder if these inverters are somehow installed incorrectly or have something enabled that is causing such large EMF readings. The readings are in the range of 150 mG (milliGauss). Any help appreciated.
