I've recently moved home and inherited a solar setup on the UK's Feed In Tariff, which I'm reluctant to interfere with for the time being.
My question is whether I can use a MultiPlusII as in the diagram below, to 1) charge a battery bank rather than feed in to the grid, 2) use battery charge overnight (less solar than demand) down to a pre-set battery charge (20%?) and 3) keep a small load (fridge) running in the event of grid loss?
I understand that in the event of grid loss, the inverter will anti-island shut down so the batteries won't be charged even on a sunny day.
My main point of confusion is that the MultiPlusII's AC connections are labelled as outputs (I understand the difference between O1 and O2) and input - so I'm not clear whether the MPII can actually output energy through the terminal labelled Input when the batteries are sufficiently charged, and demand exceeds supply.
I'm a programmer by trade who has previously worked on embedded systems, so I hope to expand and augment the setup I've drawn above (with demand shifting, and using PowerAssist with a generator for offline use), but I want to check I'm not completely barking up the wrong tree to start with, expecting power to be Output from the Input terminals!
Many thanks!
