northtown2022 avatar image
northtown2022 asked
I have a Quattro 48/5000 would like suggestions for a generator
I have a Quattro 48v/5000 I will be installing next spring at our off grid cabin in Northern Ontario . I am planning to start with single phase and a second Quattro later for split phase.
I am not sure if I can use a split phase generator for this or would it be better to go with a 48v generator?
Can anyone using this inverter please recommend a generator that they have tested that works well to receive a start signal from cerbo gx?
48v batterygenerator auto start
ludo avatar image
ludo answered ·
Depends on how much you want to spend. I'd go for a surplus Onan, you might have to be creative to get the interfacing done
Cerbo GX - Generator auto start/stop
Automatic Generator Start/ Stop [PDF]
Automatic Generator Start/ Stop [Online]
Which relay and control to use?
How to wire generators with a three wire interface.
