![fd6babdd-18c5-4ee1-8eac-776812e4006f.png](/storage/attachments/40437-e73eb62b-cd07-4939-9daf-7d9a42a8dcab.png)
Battery minimum voltage of 0.00v would indicate a blown fuse/breaker between the mppt and battery.
If fitted check the fuse in the underside of the mppt.
Were can i find the fuse?
You have found the cause of your blown battery fuse though.
Time for a tidy up.
Ok i know you are all right it was a mess! Cleaned that all up but now my mttp won’t switch on any light…. it looks dead… i always had a light…
Have i truly fucked it up?
is it this thing? If so can it be switched back on or do i need a new one?
A 30 or 35 amp fuse would suit.
It should have an ATO fuse in it, your pic is blurry. This ia an automotive fuse fitted to cars and trucks since 1970's, and will be easy to find in any auto store, servo, gas station etc...
When the fuse blows, the wire link in the middle breaks.
Ok i onow you are all right it was a mess! Cleaned that all up but now my mttp won’t switch on any light…. it looks dead… i always had a light…
29 People are following this question.
