Hi All,
I am new to Solar and have just installed my first off grid system at home. It is 3 x 175 Victron panels, a 150/35 controller and a VE.direct smart 500W inverter and a 12v 100ah LifePO4 battery.
Using the Victon connect App I can see that the panels are generating power (50 - 100w) which considering the very cloudy September day in the UK might be about right.
But I do have a question on the voltage. The panels are installed in series, so the votage is reading around 55 volts, fluctuating up and down. I believe this makes sense because mounting the panels in series keeps the ampage the same but increases the voltage.
My battery, inverter, etc, are 12v. Is this ok that my solar PV voltage is much higher than the other items? The items were sold as a "kit" from a shop so I assume it should work absolutely fine together, but I'm very new so would appreciate someone with more experience reassuring me :)
Many Thanks!
Tom
