I'm wondering where the +5V power for the Pi Zero USB is derived from.
https://datasheets.raspberrypi.com/rpizero/raspberry-pi-zero-reduced-schematics.pdf
In the above link, the USB socket J10, has its power from "VBUS" which does not appear to be referenced elsewhere on the sheet. The power input socket J1 connects its power to +5V, so apparently does the 40 pin header (pins 2&4), J8.2, J8.4. However, if the Pi zero is powered by 5V input to pins 2 &4 on J8, there is no power on the USB socket.
Does any one have any more information on this? I did not have this problem with the Pi3... but I can't get more of these at the moment...
