I need to reduce the charge rate from 70 amps to 40 amps while charging up individual batteries. I use Victron Connect and make the change. The charging amp line has a little green check appear after a few seconds. Problem is, the battery is still being charged at 70 amps. What am I missing to get the change to take effect.
