mindaugas avatar image
mindaugas asked
SmartSolar 150/85 does not show data on app while VE.Direct connected
I installed SmartSolar 150/85 and after firmware upgrade I realized that app is looping between Fetching Data and Connecting. While Fetching Data I can see that app presenting power data in backgroundscreenshot-20220920-113702.jpg
When I disconnect VE.Direct all works, I can manage all settings and can see all parameters
Also in app I also can not see any parameters on top menu
MPPT Controllers
klim8skeptic avatar image
klim8skeptic answered ·
Looks like a hardware limitation for early hardware versions.
(*) Note for early versions of SmartSolar MPPT 150/85 and 150/100: it is not possible to use both the VE.Direct port and the built-in Bluetooth Smart function at the same time. When connecting to VE.Direct, the built-in Bluetooth Smart function will not be available. These early versions can be recognized by their part number:
  • SmartSolar MPPT 150/85 Tr. Early version: SCC010085210.
  • SmartSolar MPPT 150/85 MC4. Early version: SCC010085310.
  • SmartSolar MPPT 150/100 Tr. Early version: SCC010100210.
  • SmartSolar MPPT 150/100 MC4. Early version: SCC010100310.
The same models, but then with a different part number do support using both the VE.Direct port and the built-in Bluetooth Smart function at the same time. As do all other SmartSolar MPPT models.
