derrick thomas avatar image
derrick thomas asked
Need clarification on usage of DVCC
I will soon be installing a system consisting of 2 multiplus 2 2x120 in parallel, cerbo gx, mppt 100/50, smart shunt 500, and a couple of gx tank 140. My battery bank is 4 12v 200ah lifepo4 wired series/parallel for 24v system (internal bms with no external communication). I have been reading all I can find about DVCC and assume that I should enable DVCC so that the multi's and the mppt will all get the voltage and current information from the shunt instead of operating independently? Can someone please confirm what is best practice for my situation? Much thanks.
DVCC
nickdb avatar image
nickdb answered ·
The use cases of dvcc are well documented in the related manual. A quick search should locate it for you.
derrick thomas avatar image derrick thomas commented ·
Yes I did see that but it was not 100% clear to me hence the question.
