Remote Console works OK over VRM but is unreliable over the LAN. Is this because ports other than 80 need to be open? I would prefer to use the LAN to reduce the delays apparent over VRM. Using the debugger in Firefox there seem to be some references to Port 81 which I do not fully understand.
I would also like to use port mapping as a way of accessing Remote Console via the internet for the same reason. Which ports need to be open for this?
I have a Multi II-GX 48/5k running s/w 4.79
