This is my exact setup - clamp meter on incoming municipal supply - some non-critcal loads between clamp and Multiplus - critical loads on AC1 out. I am getting the correct readings as per images but had hoped there would be a split between between critical and non-critical loads but assuming you will only get that if I ditch the clamp and use a E112 meter in same postion ? Is this because the clamp meter replaces / effectivly moves the internal measurement of the current from inside multiplus to the remote position of the clamp - this vs adding a second reading like a E112 meter will ?
