samnarly avatar image
samnarly asked
Is it possible to AC couple an 8kva growwatt inverter with a victron 10kva multiplus inverter
I have an existing system, 10kw of panels going through a growatt 8kva inverter tied to grid, feeding back 5kw. I want to install a victron 10kva multiplus inverter and 30kw of batteries, to try and run off batteries at night and reduce bill dramatically. And be sweet if grid goes down. Does anyone know if this is possible?
Thanks in advance
ac coupling
sharpener avatar image
sharpener answered ·
I can't see any reason why it would not work
AC-coupling and the Factor 1.0 rule
AC-coupled PV with Fronius PV Inverters
