fapel avatar image
fapel asked
SmartSolar charge controller 100/50 not accepting all AMPs ?
Here is my setup:
(3) GoPower 190watt panels connected in Series:
24.09 Voc each
9.45 Imp each
300AH LifePo4 battery (at 50% charge)
Using a multimeter, I show about 70 volts and 7 amps coming from the panels.
The controller shows (about) the correct voltage, but never goes above 2.2 AMPS, so I have never gotten more than about 150 Watts supplied to recharge the battery, when I should be near 500 watts.
What's the issue or where should I start?
Thank you!
smart solar charging behaviour
