I installed a multiplus 2. The AC out 2 never came live with shore power feeding AC in and AC out 1 just drains the battery. The only function that works is the inverter.
No I don't have the dongle.
If you have sorted your wiring, then you need either the dongle or a GX and the vrm to program to your needs.
The base programming probably does not match your needs at all.
Also have a digital meter handy instead of guessing if there is power at the terminals.
60 People are following this question.
