tothepoint avatar image
tothepoint asked
App on android for smartsolar chargers.
Been searching the internet for hours concerning info about the app for android and smartsolar.
Are the setting possibility's all the same in any smartsolar charger ?
I mean: Have the larger ( higher V and A ) more setting possibilaty that for example the 75/10 model ?
Tnx in advace
JP
smart solar set-up help
kevgermany avatar image
kevgermany answered ·
The app is Victron connect.
It has a demo library feature which allows you to select any Bluetooth Victron equipment and see the screens, settings etc. You can adjust settings, save them and upload to the actual equipment if wished.
As far as I know the only difference in the settings between the models is if the charger has load terminals or not. But you can check on the models you're interested in by using the app.
tothepoint answered ·
Tnx, will do. Humble greetings JP
