modrok avatar image
modrok asked
Victron BMV-712 - +B1/+B2 Wire Removal
I recently had a Victron BMV-712 installed by someone else however I have worked out that they wired the temperature sensor incorrectly.
I am trying to release cables from the +B1 and +B2 terminals on the shunt however I have very limited visibility in the spot the shunt is installed.
What is the "trick" to get the +B1 and +B2 terminals to release? There is a small orange "clip" but I am unsure how this works. Any assistance would be really appreciated.
Cheers,
Jeff
BMV Battery Monitor
wkirby avatar image
wkirby answered ·
You need to push the clip down towards the PCB (in the opposite direction to the way the wire pulls out).
If you can see (or feel) a small slot in the orange clip, this is to aid pushing in that direction with a small screwdriver, then the wire should pull out easily.
modrok avatar image modrok commented ·
Hi WKirby - thanks heaps for the response - this did the trick, much appreciated!
Cheers,
Jeff
shammer1 avatar image shammer1 commented ·
Plugged a wrong wire into a port and could not get it out, wire was too long. This was exactly what I needed to get it back out. Thank you so much.
