we need to know the voltage of your panels also. Also you can try Victrons mppt calculator.
Hi Steegergrid. thanks for your reply. Unfortunately no chance to get info on panels voltage. I am not on the boat now. I would need to replace a Tristar Morningstar TS MPPT 60/M. Specs. are maximum battery current 60A, nominal maximum input power 800W. What would be the Victron SmartSolar equivalent?
If you're looking for a direct replacement for your morningstar a Victron Smartsolar 150/60 or without bluetooth Bluesolar 150/60 should do it, given the morningstar was wired and chosen correctly.
I just looked up the max voltage of the morningstar which is 150V so a Victron charger with the same maximum input voltage should work. 60 amp charge current can stay the same.
68 People are following this question.
