leftcoastman35 avatar image
leftcoastman35 asked
Ve-bus BMS charge disconnect - how many VE.Direct devices can be connected?
I have a VE-bus BMS where the charge disconnect output is currently controlling a Skylla-i 24/80 via a Skylla-i remote on-off cable
https://www.victronenergy.com/accessories/skylla-i-remote-on-off-cable
I intend to add FIVE SmartSolar 100/20 MPPT. My understanding is that each MPPT will need to have a Ve-direct non inverting remote on-off cable connected to the BMS charge disconnect output.
https://www.victronenergy.com/accessories/ve-direct-non-inverting-remote-on-off-cable
Will this work or will it exceed the 10mA max source current limit for the ve-bus BMS charge disconnect output?
VE.Bus
