I've got an installation where east side has 6900 peak and it's not possible to add a second cable.
-> any insights if there will be a bigger mppt sometime? e.g. 250/115
regards,
Andy
regards,
Andy
Hello @N-DEE …..I must confess the question is a little cryptic but have you considered paralleling two or more 250/100 MPPT units? Many can be paralleled to handle more power. They are networked so they share the load.
You can have multiple mppts each with their own pv array, coordinating charge.
@rikhf @Trevor Bird You can, but it makes no sense, because they will individually track / search and kick each other around. MPPT controller are not like DCDC charger, they vary the load on the input to find the highest power point, they find one, canibalizing the power from the other, then the other starts a new search, kicking the first in the b... You get the point.
Hi together,
Yes I know that we can't put two Trackers on one Solarcable.
Thats why I was asking if there might be a bigger one than the 250/100 in the future.
br,
Andy
71 People are following this question.
