I tried to connect an EM24 RS485 to a Multiplus II GX using the original Victron RS485 to USB interface.
The EM24 is already installed and metering. I connected it with the interface cable to my laptop and had access to the EM24. Everything was fine.
Then I switched the interface cable from the laptop to the Multiplus. As I put the plug into the USB port all LEDs in the plug flashed an then it died.
At the moment the Multiplus is only powered via AC-IN. No batteries or anything else is attached.
Does anyone have an idea what I did wrong?
Thanks
Guenter
