Dear All
I recently "became" a Victron owner and I am doing most of the installation myself. The learning curve is sometimes limited due to family (kids!! should i say more).
As stated above, I am not sure if I should use a ET112 or NOT? Let me explain.
I run a 48V system (Mulitplus 2 - 5000VA, CerboGX, SmartShunt, 150/45 MPPT etc) to power my 230V needs for my house (Grid tied). I will be splitting my DB box into "essentials" and "Non-essentials via the AC1 and AC2 output ports, therefore, all my loads will be after the Multiplus. Currently it is running already some loads via battery (but the mppt is not connected i.e. no solar feed).
I may not back-feed into the grid so I have to install (I assume) ESS with Zero back-feed function.
My headache started when someone mentioned that the ET112 response time is somewhat slow and they are running it with the internal CT to measure current/consumption. However, a V member pointed out that the ET112 is much more accurate and can capture data that can refine peaks, idle at specific time-frames.
So, should I use my ET112 or not when running all the loads through the Multiplus2 and will it work (no back-feed) without the ET112?
Hope my question is clear. Please let me know if I should add any information.
Mvg
