Hi - I have a Camper Van and have conected it to external power with 16A Current Limit set on the Multi Control Plus. The external power has enough capacity to deliver 16A.
But everytime the power consumption is moving to a little bit over 2kW the system is having an overload failure… Is the Multiplus Compact not able to route the 16A to the camping van??? Is it only able to supply 2kW at its max, even if the inverter is not in use?
Many thanks!!!
