We are currently using a cerbo gx with nothing connected to the CAN Interfaces. Is it necessary to terminate these please.
Each CANbus on Cerbo has TWO RJ-45 connectors so a termination IS required for each bus if this is "the end of the line". There's no reason the bus can't run through Cerbo to other pieces of equipment.
And no you do not need terminations plugged in if you aren't using the bus.
31 People are following this question.
