We did a test with my MPP100/30 and the current remains stable until the end of the absorption-time. The SoC of my 180A Lifepo4 will always reach the 100%. My 180A Lifepo4 battery is from CS batteries in Germany. This LFP is equipped with Prismatic cells. We did the same test with my IP22 set on Li-ion. Before we started the SoC was 80%. Once the IP22 was in absorption-modus the current was dropping down (what is normal). But, we discovered that de current was going even to zero for a few seconds and than it will comes again. For so far has I now is that the absorption current may never go "out"...? Also the SoC came not back to 100%. Is a SoC from 100% so important?...No....but we did a test to see of the IP22 has the same algorithm than my MPPT100/30.. Further....on the IP22 the setting for lithium is market has "Li-ion" My battery is a Lifepo4....Could that be the reason that the IP22 do not have te samen algorithm like the MPPT ?
I cannot believe that a Victron use another algorithm in his IP22 chargers than they use in the Victron MPPT's
Is a IP22 not compatible for Lifepo4 battery's ?
I will "think" no but...what is than the difference between both chargers?
To do a second test with the IP22 I will first modify (only) de "maintenance" current down to 12,8v (lower is not be possible) and I will set the tail-current to 0,8 only, to see what the IP22 will do with this settings.
