fabrice avatar image
fabrice asked
Voltage problem between neutral and earth in battery operation.
I have an old Phoenix multi 24V/ 1300W that still works. I have a problem with the neutral which generates current. I connected the phoenix to ground as well as the mppt. The phoenix is plugged into an isolated site without a generator or edf....
Should I touch J33 or something else...?
thank you very much.
Fabrice
Grounding
lifeingalicia avatar image lifeingalicia commented ·
blue wire on PE (earth) ?
fabrice answered ·
No, I plugged in a ground but I only had this cable left.
I have current in the neutral at the 80v output. Do I need to install a neutral contactor or change a Phoenix setting?
thank you
How did you measure the voltage? Against PE?
You can only measure a current if it can flow over a load.
Ground, earth and electrical safety
