Andrey Karadimov avatar image
Andrey Karadimov asked
BMV-700 to PC
Dear all, (new in this forum and victron)
Can I connect directly BMV-700 (not 712) to PC (linux) - usb preferably? What I need? Any available communication protocol description?
I assume the cables provided with the bundle are not sufficient
Thank you in advance for the silly question
BMV Battery Monitor
Alexandra avatar image
Alexandra answered ·
@andrewhack
You can get a VE to usb cable. Not in the kit box. I have not used it with linux, only windows and my phone, so can't comment there.
And what are you wanting to do there? Some logging?
Andrey Karadimov avatar image Andrey Karadimov commented ·
yes, logging to home assistant for example
johanndo avatar image
johanndo answered ·
USB to RS232 cable 3.3V or the Victron accessory Ve.Direct to USB Adapter.
You can use the Victron Connect program on Windows, or a serial terminal, the BMV broadcasts the values on the interface in human readable form (ASCII), search for Ve.Direct TEXT protocol and Ve.Direct HEX protocol. They are published by victron for download after registering your email.
https://www.victronenergy.com/support-and-downloads/technical-information
thank you
wkirby avatar image wkirby ♦♦ commented ·
Remember, the signal level for BMV is 3.3V TTL, do not put RS232 signal levels up it.
3.3V TTL and RS232 are completely different.
