simat avatar image
simat asked
Availability of Isolated USB - RS485 transceiver
Due to the global issue of chip stocks, the Victron recommended "Hjelmslund Electronics USB to RS485 Iso converter" hasn't been available for a while.
Can anyone recommend another Isolated RS485 transceiver for a Multiplus II 48V/10000, is anyone using a RS485 repeater ?
My ET112 modbus meter will be 50 metres away at the supply and baud rate will be 9600.
Best regards
Simon.
Multiplus-IIrs485
simat avatar image
simat answered ·
I can confirm that the following works with an ET112 over 50 mtrs away.
The RS485 bus is terminated with a 120 ohm resistor at both ends across A and B, note the 2 x 6N139 opto-isolators and the gap on circuit board, also has 4 x PTCs that would direct a surge / lightning to GND.
rs485-repeater.jpghttps://www.ebay.co.uk/itm/133340194827
The RS485 adapter used was a cheap FTDI £10 one from Amazon. I've used these on a domoticz system reading other modbus meters for several years.
https://www.amazon.co.uk/dp/B07SD65BVF
I confirmed it had a FTDI chipset and was recognised by the Cerbo GX using dmesg on the command line in Venus OS over SSH.
Hope this helps
Simon.
gazza avatar image
gazza answered ·
I had a similar problem, and this was my solution. It will not have the same level of "isolation" but I considered the risk to other parts of the system to be low. As a cost effective solution it works for me. Just be sure you don't buy a USB to RS485 dongle that uses the CH340 chip!
https://community.victronenergy.com/questions/148423/et112-communication-link.html
wkirby avatar image
wkirby answered ·
Another way would be to use a USB isolator to form the isolation barrier there, then use the Victronn USB-RS485 cable.
Something like: DSD TECH SH-G01A or any other model using a ADUM3160 chip.
Rob Duthie avatar image
Rob Duthie answered ·
Hi
I use the DTK RS485 converter with a range over 1km with no issues.
it has a USB port which plugs into the raspi and the other end wires into the smart shunt ET112 etc.
DFR2658C is the model i use
I have sold hundreds of them for use in Victron and Fronius systems with RS485 with remote smart shunts.
You can buy them on ebay or ali express
Regards
Rob D
NZ
gazza avatar image gazza commented ·
Which is what Victron describe as a Zigbee connection right…?
Rob Duthie avatar image Rob Duthie gazza commented ·
Hi
Correct they just buy them in and resell them, just like i do, its the same thing.
Regards
Rob D
NZ
PeterM avatar image
PeterM answered ·
dansonamission avatar image
dansonamission answered ·
Juha Tuomala avatar image Juha Tuomala commented ·
@dansonamission how does it fit when USB ports are close each other, is that integrated plug too thick? If not, it looks like perfect solution.
dansonamission avatar image dansonamission Juha Tuomala commented ·
@Juha Tuomala fits fine, it’s the same one that victron sells. The plug is no bigger than a standard cable, maybe just slightly longer.
Juha Tuomala avatar image Juha Tuomala dansonamission commented ·
Good, I like the formfactor that it has bare wires at other end. Gotta get few of those. Thanks. @dansonamission
