hn3574 avatar image
hn3574 asked
Difference in Multiplus II models
I’m looking at using a Multiplus II inverter charger for an RV application in the United States. The trailer is 30amp only, so no need for the 2x120v Multiplus II.
Is there a reason that the 2x120v Multiplus II is the only one I can find available? Seems like the inverter I need is a Multiplus II 12/3000/120, but it’s not available anywhere.
The 2x120 is significantly heavier, and seems to be overkill for what I need. Am I wrong here?
Multiplus-II
snoobler avatar image snoobler commented ·
You are not wrong.
As far as I can see, the only downside to the MP I is the higher idle consumption. That's what I'd go for.
hn3574 avatar image hn3574 snoobler commented ·
Good point. And I was looking at a Multiplus II, but it looks like that is only available with 230V @50hz output.
Looks like the Multiplus II 2x120 is the only 3000VA inverter/charger with 120V @60hz besides going with the Multiplus 3000VA. And at that point it comes down to the form factor? Not sure I can fit the Multiplus height…
