debug avatar image
debug asked
Do BlueSolar MPPTs log data onboard?
I've very interested in using the History - Thirty-Day graphic functionality in my 75/10 BlueSolar charger controller mppt. I just tested out my first charge and the mppt functioned properly but there was no data for me to review. Do I have to be connected to victron connect at all times to record data about charge state and such? Or are the mppts supposed to be logging the thirty-day graphic data using onboard storage?
MPPT Controllers
The MPPTs will log 30 days of history internally.
You will need VictronConnect to view that history.
Give the MPPT a few more days of normal operation and then check the history in VictronConnect again.
debug avatar image debug commented ·
I performed a 2 hour charge and when I plugged it into victron connect it showed 0Wh, no history although a second source and battery voltage showed a two hour charge of ~3000 mAh. Is there some minimum, or why didn't it log the data from that short charge?
