daniedp avatar image
daniedp asked
Multiplus and smart solar communication
Good day
I currently have a multiplus 12/1600/70 , I also have the ve smart dongle, to monitor the inverter remotely.I would like to connect a 100/20 amp smartsolar MPPT to it, to enable to also charge through solar.
Will the multiplus and MPPT communicate with each other via Bluetooth or do I need to set something up, as to ensure I am not overcharging my LifePO4 lithium battery?
Thank you
Multiplus-IIMPPT SmartSolar
nickdb avatar image
nickdb answered ·
You will need to get a gx device like the cerbo.
daniedp avatar image daniedp commented ·
thank you for the response.
would that be the only way ?
i run a very simple system, the gx is a bit of an overkill on my small system
nickdb avatar image nickdb ♦♦ daniedp commented ·
You could probably use a Pi but that's beyond my realm.
