Is there any working OS for PI 4 8GB?
Raspberry Pi 4 images are here:
https://updates.victronenergy.com/feeds/venus/release/images/raspberrypi4/
Yes, I know but non of them seems to work on my Pi 4B 8GB. When I try to connect http://venus.local, only thing I get is web page cant be found :-(
Yes, AFAIK.
Ok, do you perhaps know which one I should use, I have tried almost all versions released in 2022.
@Kim_Hilding there is support for RPI 8Gb, both the revision 1.4 and 1.5 boards.
It is currently in Beta and details can be found here. The beta images can be found here
If all else fails, you can assemble an image with the Raspberry Pi 4 kernel from Debian. Here's a build script to automate assembling such an image:
https://github.com/M-o-a-T/moat-victron/tree/main/scripts
I'm running two setups built by this script, no problems so far.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
49 People are following this question.
