Had this charge controller well working four years. Now it has stopped. When I disconect from the batteries it still shows voltages around 14V. When I disconect the solarcells it goes down to 0,8 on batteri. Is this right?
Fuse ok. All contacts ok.
Replaced and testet with another old regulator and it works.
It seems that the Victron some how has frosen with 14 V at the battery and then stops charging. Can this happen?
64 People are following this question.
