pedaaa avatar image
pedaaa asked
Fronius Modbus "float" setting also working?
i just started my Victron installation for test purposes, and have not set up my Fronius Modbus connection correctly.
It is still on Modbus TCP "float" instead of the Victron-required "int+SF"
I wanted to change this later.
BUT...
i can see my Fronius Inverters and all its data on all Victron Display, VRM, etc.
Seems to work fine.
So... is "int+SF" really required at all? Or does it work with "float" also anyhow?
If so it would be nice, because then i would not need to change all my other external modbus datalogging, etc. that already exists
Or are they some specific registers, that only work on "int+SF" correctly?
Fronius
