Manual says mount on a vertical surface. Is there any reason why I shouldn't mount the unit on a horizontal surface? It would be much more convenient in my situation to mount it horizontally.
It relies on convection through the fins on the back for cooling. These units get quite hot if used hard. Best mount vertically with good airflow.
Another possible issue is water protection. From memory the IP rating only applies if mounted vertically with connections down.
@kevgermany Thanks for your quick reply. Your point about cooling makes perfect sense and on that basis I will reconsider my installation. I hope water protection shouldn't be an issue. Many thanks.
38 People are following this question.
Camper electric; combining Multiplus Mppt and Orion smart DC-DC
Orion TR Smart / 360 Watt wird extrem heiß und schaltet dann Ladung ab
Can i chassis ground my isolated 12/12-30 DCDC
When will fix be issued for Orion DC DC to communicate with Smart Solar?
Where do I put the master switch for a battery to battery charger two battery system on a boat?
