I have an isolation transformer, model 7000w/230v/32A. My problem is the output voltage is reading 256v. I'm concerned that this higher voltage will damage my appliances. I'm also surprised that it is this high when the input voltage is 240v. Why is the output higher than the input? Everything is wired as per the instructions with a jumper between J5 and J7. Thanks for any advice.
