I have installed a Victron 65A LVD in my car to shut down power to a caravan fridge when the car is not running. There is a residual voltage of 2 to 2.8 v when the LVD is either shut down or if the remote circuit is open. Any suggestions?
1) Don't worry about it.
If 1) does not apply, then add a resistive load, and measure the leakage current. This should be < 1mA, so a 1kohm resistor should pull this down to <1V.
26 People are following this question.
