amt avatar image
amt asked
Anyone in USA using Quattro-II 230V?
I am looking for a inverter to power a 240v mini-split, and want lowest idle power consumption possible with dual A/C inputs. Quattro-II seems like the best choice. However, I don't see a lot of resellers showing this model (24/5000/120-50/50 230V) for sale. I intend to only use 240V loads (the mini-split), and A/C input will either be 50amp/240V shore power, 15/30Amp/120V with step up transformer to 240V, or 17.5Kw GenSet (should be 240v capable but confirming).
Wondering if anyone has experience with this model, especially in an RV in the USA.
Thanks!
Kevin Windrem avatar image
Kevin Windrem answered ·
There have been previous discussions on this forum about doing what you suggest. There is also a system diagram showing such a system but with an autotransformer to create 120/240 split phase:
AT-1 split phase 240V to 120-240V with Quattro 240V
If all your loads are 240 volt then you would not need the transformer.
As far as I can tell, none of the Quattro or Quattro II models are UL certified. Only the 120 volt MultiPlus models have a UL certification.
missingegg avatar image
missingegg answered ·
I am researching a very similar topic, and trying to remember a lot of my college electronics/physics education from many years ago. In my case, I'm designing a fully off-grid cargo trailer as a workshop, where all power comes from solar and a lifepo4 battery bank.
I do wonder whether there's really a need for an autotransformer in the system design. The small 240v mini splits I'm looking at often have a rated current of less than 5 amps. For example, a Senville 12000 BTU SENA-12HF-Q has a rated 3.72A when cooling, and 4.1A when heating. If the mini split is the only 240V load, perhaps imbalanced power draw on the 120V phases is manageable. Or to put it another way, if you have two 15A 120V circuits, and an inverter that can supply 20A 120V to each side, then a 240V load that pulls less than 5A doesn't need to worry about unbalanced 120V loads? It seems like in this scenario, one could save on the expense of adding an autotransformer to the electrical system. Or am I being overly naive about how these systems work?
