lazza avatar image
lazza asked
Can an old BlueSolar MPPT 150/85 CAN-bus be used in Color Control USB port?
Hi
Is there any way of using the old-type BlueSolar charge controller MPPT 150/85 CAN-bus (SCC010085000) on a Color Control GX that already has the single CCGX CAN port taken up with the Battery BMS?
I know that you can use the VE Direct to USB interface for the newer SmartSolar types- I wondered if you can use some kind of VE Can to USB interface for these older versions?
Or is there another option?
VE.Can
