On a Multiplus, I would like to disable AC2 if the AC current limit setting is below a certain amperage. This would be to prevent the Assist function from using battery power on AC2.
Thanks.
Thanks.
Thanks for the reply @Boekel.
If only the AC Input Current Limit parameter was available to read in an Assistant.
I have tried using battery SOC below 80% to turn AC2 off but then AC2 does not turn on at all even when the battery is full. Maybe I need to understand the system better.
That makes sense to use on & off but what happens to the existing control where AC2 is off when no shore power is connected? Does this default control still work or do the Assistants overwrite it completely?
5 People are following this question.
