Can anybody show me a lead to the fixing hole dimensions of a 305watt Victron solar panel please
If its not in the spec sheet on the victron site under the dimensions, then you will need to find someone with the same model panel
In the manual there is this re the grounding holes (maybe the same)
26 People are following this question.
